Where to get accelerator pump rebuild kit.
fish1102
Hey guys, I am new to the forum so I hope this in the right place. I have been reading the forums for a couple of weeks and it has been a wealth of knowledge, I need to find an accelerator pump kit for a 1999 GTX limited 950. The pump was stopped up, I got it unstopped but the little rubber (I think it's a check valve) broke. I guess I need to get a rebuild kit for the pump itself. Thanks in advance for the info.
Thanks, I checked up but I couldn't find a rebuild kit for the accelerator pump, just some individual parts, unless I over looked it. I have searched around on the internet for quite some time now but have not found one yet. Any other ideas. Thanks a bunch.
Hopefully these pics will help. If you need better pics, please let me know. The rubber piece in the first pic is damaged, I just put it together the best I could for the picture. Thanks
Thanks, I will give them a call tomorrow. Am I calling the small rubber part the correct thing, a check valve, or is it called something else.
I couldn't tell from your pictures. Go to the "Parts" link and try to locate the part in the vicinity anyways, so you can let the sales person have a idea of what you need.
Karl
I called them today and they said that the parts breakdown that we see online is all that they have to go by also. Any other ideas? I can post some bigger pics if you think that would help. I have been everywhere that I can think of online including mikuni website and still can't find a breakdown of the inside of the accelerator pump with this part included or where to buy it.
On some models you can't get any fuel pump "parts". You might have to buy that expensive pump assy.
Karl
On this model there is not a check valve in the fuel line, it is inside the acc pump, it is the rubber piece that is broke. I believe that i can make it work by just putting the accelerator pump back together with out the rubber check valve inside and putting one (check valve) in the fuel line, should be the same difference, right. I looked all over town today for a fuel check valve, with no luck. I'll have to order one offline, I guess. Should be good to go then.
