where to connect water hose for flushing
raider352
this season I'm going to the beach to put the xp trought it paces and I'm not sure where to connect the hose to flush all that saltwater out afterwards.
I looked at the back of the pump and you got like 3 or 4 different garden hose sized outlets in there. can anyone point out the one i should hook up to? any special instructions?? thanks everyone.
http://partsfinder.onlinemicrofiche.com/seadooforums/Seadoo_oem/Seadoo_PWC.asp?Type=13&A=64&B=7
almost forgot, it's a stock 1999 xp with the 957.
Looking from the rear, it is the pipe that sticks out about 4 in. next to the pump in the top rt hand corner. It has threads in the end for a garden hose. Engine must be running when you flush or you can cause engine damage. Flush for about 3 minutes only. Flushing for a extended period of time can overheat the driveline.
DAWG
When i do mine, i use a quick connector and coupler on the hose. Picked them up in the garden section of walmart. Just make sure you unscrew the connector when you are done.
I have mine where I can put my Saltaway adapter on the hose, so I open the seat to flush. Rinse ski & trailor down with fresh water hose and into inlet grate & nozzel, shut water off. Remove seat and airbox !/4" center rubber plug. Attach hose to backflush fitting. Start motor,
then turn on hose to low medium and idle engine 1-2 minutes, lower ski front, then shut off water. Bip a coupla times to get the water in tuned pipe out into exhaust, then fog into airbox hole your fogging oil with straw tube into engine bip, fog & kill. Put fog plug back in and get the
wet vac out and vac any water in compartment. Use your favorite anti-corrosive spray, like Boeing T-9, or WD-40 everywhere, engine wires, ect ect. grease the zerks, white lithium grease with small paint brush on all carbs, cables, aluminum parts, ect. Thats about it. Bill
