When I bought my Speedster, the previous owner told me he had replaced the starboard rectifier/regulator since it didn't seem to be charging the battery. He gave me a brand new one for the port side as well. We had taken the boat out with him for a test ride, and all was good. Checked it out thoroughly and all was good. Got it on the water the first time after buying it, and all was good. Second time all was good leaving the boat ramp....went over to a small island in the lake where everyone hangs out.....stayed there for a few hours and went to head back to the ramp.....starboard engine wouldn't crank. Port cranked, but very sluggishly. Ended up getting towed back to the ramp. Got back home, did some research and found out that there is a 30amp fuse in the charging circuit that is known to blow. Checked mine and low and behold....it was not only blown but just about melted completely. I replaced the fuse and the fuse holder, as well as put in a new battery. Fires right up with no problems......in the driveway. Weather turned bad at the end of last season and really haven't had a chance to get it back in the water since to test everything out.
All that to say, after doing some reading on the subject about other Speedsters, I am convinced that the original rectifier/regulator had failed, allowing too much current to go through the fuse, blowing/melting it and not letting the new rectifier the previous owner had installed charge the battery, and hence leaving me stranded in the water. I'm adding a voltage gauge before heading out this season too. The idiot lights will come on about 30 seconds before the engine fails.
