98 speedster twin 800's passenger side motor has oil streaking from it every few uses.. Im sure its not good but will it be fatal?? Maybe its comming from the RAVE, ? How do i fix it? does any1 else have this problem??.. Thanks alot!
I don’t think it’s coming from the RAVE. I think that’s coming from the exhaust gasket on the bottom cylinder of that picture. I bet if you check the manifold bolts… they are coming loose, but if they are… you will need new gaskets to fix the issue.
Might check the hoses going to the RAVES. I had almost the exact same oil pattern...just not as much. It was a cracked rave hose. Replaced and no more problem.
