jimmaki
According to the shop manual on the 787 engine in a 1998 SPX, to remove the RAVE valves, just remove the top plastic cover then loosen the two allen screws and pull the RAVE valve out. That works fine on the PTO RAVE, but on the MAG RAVE, the top of the assembly hits the exhaust pipe before the paddle clears the hole it's in. I didn't find anything in the shop manual about how to get around this snag. I think it assumes the engine is out of the ski? Tell me is isn't so. Can I take the RAVE assembly apart, i.e., unscrew the piston from the paddle and remove the bellows. My fear is the paddle will fall down into the cylinder or I'll damage the paddle or exhaust port torqueing off the piston retaining nut. Is there a simple trick? This is an annual suggested maintenance so I'm hoping it doesn't involve taking the exhaust pipe off or something like that.
PS: The PTO RAVE is not that bad but there is some encrusted carbon on it on the top side so tempted as I am to just button up the MAG RAVE and pretend I didn't try to get it out, I probably need to clean it or have problems down the road.
