What years/ models need to replace the tempo fuel lines
nh jeff
My brother-in -law has a 99 sea-doo with the 751 motor. Is this one that the tempo lines need to be replaced. I asked my nephew if he could see said lines but he was un-helpful.
To be honest I think he has a yamaha 760 but he says it is a sea-doo. This post could be all wet. I should verify what he actually has first. Sorry
Either way its not a bad thing to look into if they slide around on the nipples with ease and you can pull them off and see that they are gunked up pull them and replace them. With tools on the bench it wont take longer than an hour. The hardest part is getting to some of the parts of the system that are tucked up under the steering column. But checking to see takes no more than five minutes... And thats just the time it take to walk to the garage and pull a fuel line off.
Also look into adding a small oil filter before the carbs as it allows you to see the gas going into and also does a littler extra filtering also. The better the gas the better the performance and the less likely he would be to tear it up. Not too bad for a couple of bucks.
Anything carbed before 2002-2003 ish had the tempo lines. And seadoo did not make a 751.
