what to use for a premix 657x ?
shakedown
I just bought a 95 speedster (657x times 2) that has the oil blockoffs installed, I still have the oil (XP-S 2 Stroke Synthetic) going to the crankcase via the oil resivor, What I need to know is (1)whats the best ratio to use, 40:1 or 50:1 ?
(2) what can I use for a premix? thats going to be wallet friendly and take care of the engine at the same time?
Keeping the oil lines to the engine cases for the rotary valve shaft is necessary. The proper mix is a 40:1 mix. Keep the synthetic oil for the premix. The worst thing that will happen is it will foul spark plugs as the oil injector used a variable rate of injection with injector pump, it won't be able to do now, and it will be using more oil.
Karl
