OutkastBoss
Hello we are going to go check out an 05 RXP and I was curious about what you guys would recommend checking out on it before picking it up.
This is it here Facebook Marketplace: Buy and Sell Items Locally or Shipped
He says it will run at about 75mph!
After a little reading around on here I am wondering if it is a 115 or 155hp and I was also wondering if it was a rxp or rxp-x potentially and he just wasn't aware.
My plan is to drive down there and do a compression check with a tester we pick up from the auto parts store.
From what I see they usually have 125-135psi and you don't want more than a 10% difference.
I figured I would start it up briefly to be sure it fires up as well. Is there any issue to doing this dry or would I need to hook it up to water?
I was also thinking since its like 50 here we could potentially take it on a test run before putting it away for the rest of the winter. (we would have already bought it at that point) If we do what do we need to do to winterize it again, just throttle it out to blow out the extra water and drain the tank?
Thanks for your input guys!!
