bigJake Well-Known Member Jun 22, 2022 #1 I need to replace my ground cable on my '96 GSX. The bolt on the bottom of the engine is too hard to reach, so I was going to use this unused bolt hole. Anyone know what size thread bold I would need?
etemplet Moderator Moderator Jun 23, 2022 #2 Probably 8mm, I think 1.25mm pitch but I'm not certain. I have a big stash so I don't have to check very often.
mikidymac Moderator Staff member Moderator Jun 23, 2022 #4 No, you want the ground down at the starter where it should be.
etemplet Moderator Moderator Jun 24, 2022 #5 mikidymac said: No, you want the ground down at the starter where it should be. Click to expand... Oh I see where he is now. Yea I sure wouldn't put the ground in the place. Starter is the place to go.
rkkoeb Active Member Jun 24, 2022 #6 I have a 99 gsx rfi and looks like they put my ground cable on the engine case. Is this not correct do I need to move it to the starter
