What is this part for?
that's the rubber attachment part that holds larger parts to the side of the hull. the air intake tube is a good example and is held on by this part where there is a small plastic part glued to the hull with a u-shaped opening and it slips into the back groove and the front goes in a similar u-shaped groove. you pull on the little handle and it stretches the neck to fit right into the u-shaped groove.
I think it is for a resonator, I just found out that the ski came with one, I will be ordering one to install it. I do have the part and found it on the wall attached to the u shaped grove that you are mentioning.
