What Carb Kit should I purchase?
rkkoeb
Ok want to rebuild the carb (single) on my 1997 seadoo GTS 717. Looking for what brand/company rebuild carb kit you recommend using? I want a complete kit. This carb has never been rebuilt so I want to make sure I replace all the parts. In addition I want to replace the high and low jet as they were hard to get out and now are beat up. What is the size of both jets?
Thanks
OEM and only OEM Mikuni. ... the aftermarket kits are garbage... I have been buying from www (dot) osdparts (dot) com for almost 6 years on 3 skis and great oem kits and parts and quality aftermarket parts... not the cheap Chinese crap that fails...
Get the OSD.com kit. Buy a pop off tester and the tool to install the check valve hold downs. This will save your sanity! Read all you can here about carbs and rebuilding them. Read the sticky above this forum about carbs and adjustments. It goes in to detail about cleaning and theory of when certain stages of carb's come into play.
