weird speed sensor
bigdogmedia66
I've had this 2001 GTX RFI for 2 weeks now and the speed sensor works sometimes for analog and digital gauge, when I take a right turn. What the hell. Any ideas on what the issue could be? Thanks in advance.
well
is the little wheel jammed? spin it w/your finger, then hit it w/the hose while you hit the start button, DESS Off. it should give u a reading
OK... that makes more sens. Short, and to the point.
Make sure the wheel is spinning free, and also make sure that the mount isn't loose, and it's sitting flush on the ride plate.
Finally, give the wires a little tug at the sensor. They are known to break, and if they are... they will pull out. Unfortunately, if you find that... the only solution is to buy a new sender.
