On i just put a used motor in a 96 gtx. Its an 800 and early i hooked up the water hose it screws it by the jet pump in the back. When i did the seadoo filled up with water inside. Two leaks were just lose hoses. But it shoots water out the jet by the tow hook in the rear like 5 feet which is to much i think. My other one didnt do this so i dont think its normal. That jet hooks into the exhaust right at the top there. The water inside is coming from a hose that runs to the crank bu the exhust. It is to hook ups in the case that tee into one. Where is the other end of this hose suppose to go? I have it just laying in the bottom of the ski. It flows alot alot lot of water when i turn on the hose which fills up the hull how can i fix this??
Also whats the best way to prime the fuel system.
