water inside and no oil
stefano6
Hello Iam Holger from Germany,
I have got a RXTX260 from 2011. After 50 hours of running I got a lot of water inside. Also there was no oil in the engine for riding only 20 minutes of time. Inside the Seadoo is a lot of oil/water.
I think the carbonring has to removed, but where is the oil comming?
Thank you very much
Best regards
Holger
Was the driveshaft recently replaced? If not I believe you need the updated driveshaft non threaded and a carbon ring.
I didnt know that because there is no history on that Ski because ist imported from Florida. I will take a look at this parts soon. But I didnt know where the oil is comin out from the engine
You need to find the oil leak. Clean things up, top it off with oil, get to the ramp and run the ski with the seat off. Look for the leak. Also look at the CS while there.
