allsevensinz
Hi all, Just wanted to post something here to see what sort of feedback i can get. I have checked out the other threads about this topic but got a little lost. Anyway my bellow had rusted out and was leaking so i got one of these
http://www.jetskijunk.co.nz/index.php?id_product=673&controller=product&id_lang=1
and it seems to have gone in fine and i have run it out of water with the hose hooked up and had no leaks. Now the problem is I adjusted the red adjuster on top of the water flow regulator that all the manuals say not to. I was unsure about its setting because before I adjusted it, it was about 2mm lower then the casing its screwed into. I followed the directions from the service manual and it said screw all the way in then counter clock wise 3 turns. This made it sit about 1-2 mills proud of the casing. I also have seen a post saying set the red screw flush with the casing and turn counter clockwise 2 clicks which actual is about the same as the manual says. Moving on from that the issue i have is am i on the right track and would it possibly have been set wrong prior to me touching it or have i misunderstood the method for setting it back to factory setting?
Any feedback's greatly appreciated thanks all.
