bigJake
I developed a minor water leak inside the hull which I traced to a pinhole in the bellows in the water flow control valve on the muffler. The thing that confused me is that there were 3 washers on top of the exhaust valve to increase tension of the spring. Manal says the valves comes pre-adjusted from the factory. Is it possible the factory would have put the washers in or I'm assuming it was more likely done by the previous owner. I took the washers out and adjusted spring tension per manual - run red cap all the way in then back out 3 turns (which brings it just above flush with the housing). There had to be a reason the washers were there, how do I tell if the valve is working correctly?
