bigtexan99
I took the boat out today for the 2nd hour of break in after my engine rebuild. Engine ran flawlessly, and my adjustment of the bellows on the driveshaft stopped the small dribble I had on my first outing.
This time, all stayed dry and good. when done I backed the trailer in and loaded the boat to leave. After I had the boat secured, I opened the hood to turn off the fuel, and wow, water was coming in fast. I pulled the trailer/boat out of the water and let it drain. Backed it back in and it did the same. I pulled it out of the water and did not open the drain plugs, thinking I would see water coming out of somewhere, but no...nothing.
Drained the bildge again and backed it slowly into the water, checking every half foot for water intrusion. Got it to the point where water was coming in and then noticed that because of the angle of the ramp and the trailer, the swim platform was submerged and the rub rail was also underwater. It seems (but I'm not sure) that the water was coming in thru the rub rail portion.
Pulled it out again (no one at the ramp, lucky me) drained it, and this time unhooked the boat from the trailer so that when I backed the trailer in, the boat immediately floated instead of submerging the swim platform. Boat stayed dry. Started the engine and ran for a bit, boat stayed dry. Pulled out and headed home.
Whew, long story. Anways it seems like it only happened when the swim platform was submerged. Has this happened to anyone else? Should I be concerned or no big deal?
