Want to make sure i understand right.
super1c
Well just finnished the fuel system overhaual on my 95 gtx. New fuel lines, filters, carbs cleaned and such. Thanks for all the great info. Fired right up with no problems. No green goo anywhere to be found. Guess im lucky. Fuel guage does not work. Did all the tests, and if im right when i ohm the baffel it goes right to 90. meaning the baffel is sitting at the bottom of a full tank of gas. Where can i find these. Ive searched here and the internet and just cant seem to find what im looking for. Next did the oil injection lines, they were old and shot. Now if when i fire it up and i see the oil pulsing through the lines i know its working right. I have pre mix in it now so the lines should bleed themselves out before the end of the tank. Just looking for a little reasurance on my work. Thanks guys. CCC
Seadoowarehouse.com should have the new style float, you may need to call them because it may not be listed for your model. Your dealer should be able to order one. Or do an internet search.
Lou
attach hose to ski, fire motor, then turn water on. While idling, reach down and grab the oil pump arm, and hold it wide open, this will purge it faster.
Thanks guys, found a float for the baffle. Seadooya i did exactly that and the oil pulsed through the lines just fine. The pump seems to be working fine from that stand point. I have 5 gals of premix to run through yet so i will mark the tank and watch for levels. Now with the new injection lines and such how much drop in oil should i look for?? Just dont want to blow up, thanks for the help. CCC
