Wake tower wiring for speakers
johnathanrn
Hi all. I have a 2008 230 challenger. I would like to add wake tower speakers. Would I need to replace the stock head unit or is it powerful enough for two more wake tower speakers? Also, my wake tower is not wired for them...the holes are there but no wires. Any ideas/instructions on wiring a wake tower? Thanks.
It would depend on the power of the head unit, but I think all will agree, those tower speakers should have an amp of their own, or a channel off of a multichannel amp to work properly.
We have an Alpine Marine amp driving our Kickers on the tower. The other channel is driving the Alpine Marine 6.5"s in the boat. Running the wire can be done with fishtape or a long stiff wire. Time and patience, cocktails help!
Good luck!
How do I access the factory head unit to run the wires? And yea I believe they are self powered so no amp is necessary? So all I have to do is just give them power from the factory head unit (L and R speaker outputs?)
No, not self powered, I can't say that I have ever seen anything like that on the tower. Maybe I am using the wrong terminology.
Most head units do not have the power to drive tower speakers properly. They are usually fine for a pair of 6.5" speakers that come from the factory, but not much more. An amp is always recommended.
If you have a tip down tower, you will want to run the wires down to the pivot point. You may want to use a waterproof connector when they reach the hull so that you can remove the tower. If you don't ever do that, then you can run it straight into the hull. A hole can be drilled near the point where the tower is attached to the hull.
Then fish the wire through the inside of the hull to the backside of your stereo. You need to see what you have for outputs that are open though. You either need speakers outputs with adequate power, or pre-amp outputs to go to an amp.
There are plenty of write ups on here for stereo projects. Otherwise, call the local sterero shop and get some help. I know my own limitations when it comes to this stuff. For the same reason I don't go under the hood of my truck.
Good luck,
