Vts not working but seems like it should be 95 spx
Tgspxer
The vts in my 95 spx doesn’t seem to move with the button presses. Disconnected the motor from the box and tested the box fuses are good 12vdc both ways up or down (one is -12) and the relays click. Tested the motor hooked up to 12v power direct and the motor turns good. Is the vts module bad or does this problem lie in the motor? I have a new module on the way because it came with an mpem i needed but don’t want to swap if it isn’t the problem
THe modules go bad a lot from the rear boot getting torn and leaking water in.
Sounds like your module is bad and bad modules are known to fry MPEM's.
My model has the module inside the ebox with the mpem and the motor is up on the left side opposite the fuel fill tank with a cable running back to the rear no fuses are bad and the module is putting -+ 12v to the motor. But I have one coming anyway so I will just swap both and hope it works
