Logantw2543
Hello, I recently purchased a 1999 seadoo challenger 1800 with 787 engines in them. I’m having a few issues with them that I can’t figure out.
1- on one of the motors the compression readings are around 210 on each cylinder. And I’m not sure why that is. I’m no mechanic but that doesn’t seem right lol. The other engine is reading right around 150. Why would the compression be that high on one of the motors? What do I need to look for or do? I’ve cranked the engine without the spark plugs and had some liquid come out but eventually stopped.
2- the engine with really high compression will not crank with the plugs in. Like at all. You can hear it try but it won’t crank it. The starter isn’t bad because I actually switched the starter from the other engine and tried cranking it but it won’t. So why won’t it crank? I’m guessing the high compression but I’m not too sure.
3- the purge lines that lead up to the fuel pump and not sucking any gas out. I can feel air coming out a little when I crank by hand. Would this be just a bad fuel pump?
Sorry I’m all over the place. Just really getting aggravated with these motors lol. But any advice will help. Thanks!
