Used Solas Concord?
Ibanez540r
So I found this used impeller on Ebay, and couldn't pass it up. I tried to do as much research as I could and seems this should be fine, and the minimal looking wear on the tips can just be sharpened.?
Anything else I should be concerned with? And those of you pros, does it look like it's in good shape? Sharpening sounds farily easy, I'm very mechanical inclined and thinking just a light scuff with a file?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270438239140&ssPageName=STRK:MEWNX:IT
BTW, what is the "wps p/n 20-8071" that is mentioned?
Looks good, just check the splines and make sure they are in good shape (not worn out or wearing out). It will make a mess later on. The whole prop looks to be in great condition from the pics tho.
Have you installed it? If so, what was the outcome? It looks in good shape. Did you change pitch from stock?
