Hi Dchally, Im not an expert yet, but im on my second pwc, here is what I would look for:
- inspect the hull, make sure there are no scrapes or cracks, make sure the gel coat is in good condition, get under it with a flash light and look real closely
- drive it, make sure it runs well wide open and starting up, drive it for a good 15 minutes (dont buy it unless you can drive it)
- check the maintenance records, make sure they winterized every year and did all the other good stuff they should have, ask to look at receipts, if they did themselves, ask them to go over exactly what they did and how.
- look the engine over after you ride it, see if there is water inside the engine box, see if any leaks or strong smells of anything, check that hoses are in good shape. check the oil.
Joel
