Unusual trailer tire ware...??? Photo..
Slug-O
My drivers side tire is wearing on the inside and there is a vibration.. Ideas???
Thanks,Slug-O
Mine wore weird on the inside and was vibrating bad. It eventually developed a huge bubble on the inner wall. I'm guessing a belt broke. Maybe yours is having the same issue. Or the inner bearing is going bad on the hub.
Tyre wear
Can only be 3 things
As Rfoster said.Wheel bearings
Leaf spring bushes or shackles
Bent axle(very unlikely)
Check bearings 1st as this is the most likely cause.
Hope this helps
If it was a car I would say it's an alignment issue. I'm new to jetski trailers so I'm not sure that's possible but I just wanted to bring it up.
