I'm having trouble with my 97 SPX. To use a car analogy, the seadoo spins wheels until it gets traction then takes off. That's the best way I know how to describe the problem. I noticed it was idling a little rough when I put it in the water. When I hit the throttle it wouldn't get on top of the water but it was revving pretty high. If I held it at WOT it would pick up speed until it came up on plane then it would bite and off I went. It still wasn't at peak RPM but it was moving pretty good. As I slowed down it came off plane and quickly started to rev without much movement. This is where I would say it lost traction. If I get it up on plane I can snap the throttle or slow down and everything works as it should. The problem appears when I come off plane or when I first start.
Do you have any idea what would cause this? In the past that would happen if something got clogged in the impeller but I checked and it is clear.
