ya it is visial, if you pull your seat off and look at the bacl of the ski you will see the vts system, now if you go behind the ski and look at the jet pump(thing with the impellor in it) then you will see it has a bar on the side which will be the steering cable and then there will be another on top and that is the vts bar, it should move the nozzle up and down
