I've never heard of sealed bearing on a boat/PWC trailer. That's pretty interesting. Sealed bearings have installed permanent seals on both the inner and outer sides of the bearing so grease is contained and dirt/water, etc are kept out. You probably wouldn't be able to install bearing buddies because the grease you pump in wouldn't get into the bearing because of the permanent seals. You would have to change out the whole bearing assembly. Being on a PWC trailer they must be rated for submersion so I would just go with it. If they go while you still own the trailer swap them out for open bearings and install buddies, but I wouldn't waste the money until the bearing needs changing. Sealed bearings can last a long time.
