Most often I'm towing around town and fairly locally, but planning to go on a long trip with my 2001 Challenger. It make alot of noise when going over bump and uneven roads, more so than I've noticed than with other prop boats. Is this a weight issue? I grease the ball, and tighten the straps quite a bit to reduce what i can, but still, it worries me that the boat/trailer is going to "hop" or something if I'm traveling @ high speed. I keep the tire pressure at 5 under to allow for expanding on the highway, is this what you would recommended?
Also, if it starts to sway while towing, what is the best way to reduce or correct?
thanks for your help!!
