Ozweego
I have vessel view on my boat which has been a lifesaver by either pointing out errors or giving me an idea what's going on.
I generally don't get it out very much by myself usually have family in tow. So when on the water I don't tend to go more than 35 mph. However a couple evenings now I've managed to get it by myself to try to see what my boat can do.
Prior to buying and during sea trials we were able to get up to 55 miles an hour (onboard speedo) and about 6 to 6500 RPM. The last couple times I've been out while using vessel view which is a more accurate reading, I can only hit 4900 RPM and max out at 41 - 42 miles per hour. When I go wide open throttle to hit the 4900 RPM I'm allerted to a TPS fault with vessel view.
I'm thinking my throttle position sensor has a fault and needs to be replaced however I'm wondering if my 4900 RPM Max and low top speed is a symptom? Just wondering if there's something else that maybe holding the boat back.
Thanks
Thanks
