IDoSeaDoo
Hey guys, so I finally got my Challenger wet this weekend :hurray: Everything but the steering and the TOPS valve worked great. The steering cable has already been fixed, but I'm debating on what to do about the TOPS valve.
I noticed this from the large pressure building up in the crank case and blowing oil out of the valve cover. Pulling out the dipstick blows off a bunch of oily air. My whole engine bay is disgusting with it, I'll have to de-grease EVERYTHING here shortly.
I have confirmed that the TOPS mercury switch has continuity, so that's good. Now when I put the key on the DESS, the tops doesn't click like it should. Instead it makes this weak whiny vibration noise, like it's getting low voltage. I think maybe it's a bad solenoid, as I tested the plug, and it's getting 12v with the key on.
My understanding is that this valve is only to mitigate oil flowing into the wrong places when A BOAT TIPS OVER. Well, I figure if this boat tips over, I'll have much bigger problems and will likely need a salvage crew to pick it off the bottom of the lake. I read a post where one guy just gutted his TOPS valve. He took the plungers off of the stem and bypassed it entirely.
Are there any negative effects of doing so? Does the tops valve ever need to stay closed during normal operation?
