aquaman222
I posted my problems with my 1996 XP before, but I’m recapping it all here since I did just pull the head. Basically my ski bogged down with no signs of problems on the lake. It was running very strong, then it would not start.
When I got home I tried to start the ski and it fired right up then had a loud backfire and was difficult to start.
I have recently cleaned the carbs, replaced fuel lines, plugs and rave valves. My valves look real dirty even after only a few rides.
I checked compression and found the Mag cylinder to be at 145 and the PTO and basically nothing. Perhaps 20. I pulled the head and quickly discovered the PTO piston was fried. It looks like the rings broke and got into the head or perhaps the previous broken rave valves that I replaced had some chips that dropped into the head. Both of my old valves broke at the stems and if anything got in the head it was minimal. It could account for most of the valve pieces.
From the pics you can see how bad the PTO piston was. My head is also probably toast. The Mag cylinder is covered in carbon, but appears to have no damage.
I’m replacing the entire top-end, but I really want to make sure I get to the cause of this so the problem does not repeat.
I’m also going to rebuild the carbs and am considering going to premix.
One final note. I do not know what type of oil the previous owner was using. I drained most out of the tank and replaced with Quicksilver full syntetic.
I don’t think anything got into the bottom end of the motor but I stuck a tube down in the bottom end and vacuumed out what I could and found nothing. No signs of metal.
Any advice or comments would be greatly appreciated.
