beergut
This does not really apply to these 2-stroke skis. You have no oil control rings and have rather large ring gaps compared to a 4-stroke so a cylinder pressure leak down test really isn't that helpful. Also adding oil isn't really helpful either on these since there is plenty of residual 2-stroke oil on the rings anyways.
On these engines the best diagnosis for the pistons and cylinders is a simple compression test.
I will say a complete engine pressure test is a great test to determine leaking gaskets and seals to prevent lean conditions.
duh! i totally missed that- didnt even realize he had a 2 stroke- I'm so used to dealing with 4-stroke and diesel. leak down test in a 2 stroke will just confirm blown head gasket or cracked piston / cylinder.
