Thanks for your advice.
Ok I went and checked the neutral safety switch but don't know what I am suppose to see (i'm really a new jack). I saw the switch and a screw that held it in place but couldn't remove the screw. Explain what i'm suppose to check for.
I spoke to the guy I purchesd the boat from and he told me that he did some type of converstion that eliminated the oil pump now you are suppose to mix the oil with the gas. Do you know about this. I also noticed that the oil tank was removed but the hose lines where still attached to somewhere under the engine. What should I do about this.
I opened the fuse box and noticed a 20 amp fuse blown out. I replaced the fuse and heard a pump (suctioning or maybe blowing sound). Also it is always on, looks like it direct but there are no connection to the battery. I left the fuse out.
My original problem with my boat was that it didn't run over 15 mph. Now i see alot of other possible problems.
Please help me I would love to enjoy this boat with my family.
If at all possible maybe you can give me at call 1(347)284-4468 I'm in NYC.
