Tilting moving deck on a 09 gtx255 limitid
poolguy
Should the suspension be raised up prior or be in docking position. Manual does not specify. It seems to not want to go past 12 inches with suspension in docking
Rick
12 inches? There should be about 6 inches of travel. In dock mode the suspension should just drop all the way down until the rider deck bottoms out onto the main hull.
Actually I was referring to position when disconnecting the rear mount and tilting the back of the deck up to service the unit and remove the hull extension. Nothing says to raise suspension, just put wood blocks in front and dont raise past 13 inches in the back to prevent damage to steering cable ect.
