Throttle Control Lever
JohnG10
I have a 1995 Speedster. The left throttle control lever moves too freely. It will not stay in one position. Is there anyway to tighten it? Also the throttle control levers are not in sync with the rpm of the engines as you move them simultaneously-is there a way to adjust this?
Thanks.
Thanks.
pull the lever assy up/out and look'n from right side of assy, in the middle, you'll see a "chrome" panhead. Tighten that screw, and that will take the play out of the center lever. Above that, flush with assy, you'll see a black plastic flathead set screw, tighten that one, for the outer lever, and for F/N/R, same look'n screw, but on that lever side..
