Love the colors.
I do see a few things that worry me though....
The alignment looks to be a mile(kilometer) and a half off. This will wear your drive shaft splines out, especially with big power.
I'd use a little larger zip ties as clamps on the fuel hose connections or at least double them up and pull them as tight as possible with pliers before snipping the ends off.
Since your not using your temp sensor you could put a 1/4" fitting there to feed the stinger. Then you could have the fitting on the top of the exhaust manifold feeding the tell tale(pisser) again.
I would run it with the seat off or slid back and put a left hand on that ADA head during some WOT runs. If it's too hot to keep your hand on then you can exchange those brass plugs on top for 3/8" fittings and have them feed bypass fittings. I'm assuming that is water coming out on the top of the head and not going in, right?
Oh and on those Jetinetics RAVE caps the inside is not removed like on the original red caps. This means your adjustment spring is always on the tight side so the raves open later
