I know there are a ton of debates and threads about oils on here and I looked through a bunch but I still want to ask...
I just bought a used 99 gtx ltd with the carb's 951 engine and it currently has Amsoil hp marine oil in the oil pump and small amount of premixed gas in the tank for premix to make sure if oil pump fails it won't ruin the engine.
I just bought a jug of seadoo XPS full synthetic 2 stroke oil to use from now on.
I was wondering if I would need to completely drain the oil pump, clean all the lines out, drain the gas tank, clean all fuel lines and rave valves, etc. just to switch over to the seadoo oil or would I just be ok with siphoning out as much of the gas and oil as I can and then refilling it with the seadoo oil?
I know some people say it can possibly gunk up if you mix oils. Would it gunk up if I siphon out everything I can or is that not good enough?
Im alright with engines, no mechanic by any means. I just want to know if anyone knows anything in regards to this situation.
Link to Amsoil - https://www.amsoil.com/shop/by-product/motor-oil/2-stroke/hp-marine-synthetic-2-stroke-oil/
Any help is much appreciated.
