Hi, the shaft is seized to the impellar, I pulled hard for a good while but can not get the pump off. I was thinking of tying the pump off and pulling it with a truck but I don't want to break anything, any other ideas?
I am guessing you dont grease the driveshaft very often. Working it back and forth might get it loose eventually. You better have some patience. I have tried it a few times. Once the shaft will move just the slightest, you keep going back and forth. Keep using the WD-40 to wash away residue.
