Scott02dmb
1997 Seadoo GTS
Struggles to crank & won’t start
I’m a noob when it comes to my Seadoo so I apologize in advance if this topic has been covered in great detail. I have a 1997 Seadoo GTS that has been giving me trouble for the past few seasons. Some history, bought the ski in 2000, ran without problems until 2005. In 2005 I rebuilt the engine once and replaced the carb. The boat worked perfect in 2006. In 2007 I started having problems getting the boat started. When I could manage to start it, it would idle but struggle at high speeds. Currently, the engine struggles to crank and who knows if it will even start or not.
Everything on the ski is 100% stock. No mods at all.
Struggles to crank:
Last season the jetski would start, idle without a problem, but hesitate when given gas from ½ to full throttle. Figured it was the needle valves/ something with the carb. Rebuild the carb and same problems. Thought it might have been an issue with the valves not set correctly (i.e. too many turns tight or too lose, not exactly sure). So I gave up on the jetski and used the boat for the rest of the season.
Now when trying to start it this season it struggles to crank. The starter will give one full crank then give up. Assumed it was a beat starter, removed it, looked at it and it was mint. Reinstalled the starter, ran power directly to it (bypassed the ski’s central computer) and the starter spun without problem. Removed the ski’s computer in an attempt to determine the electrical issue but have no idea how to test.
Is there anyway to run an Ohm meter to determine if any of the electrical is shot? Or any tips on how to test?
And, at some point in removing the ski’s computer it no longer recognizes the key (no beep when the key is attached and no starter movement when the start button is pressed).
Has anyone experienced a problem similar to this?
Am I wasting my time trying to diagnose this? I really want to get my ski up and running this season. I’m not opposed to swapping in an engine and electrical from a faster ski if there happens to be a common swap for this Seadoo.
Thanks in advance.
Struggles to crank:
Thanks in advance.
