jjsinaz
So, I finally got all of the kinks worked out, that last one being the bad ignition relay. Had it out today and is ran great. Only thing is I'm still not getting top speed. It only hits about 45 MPH/6600 RPM. From all the posts I've read, this should be a 50-55 MPH ski.
It's had all of the things done to it you'd normally do. All new fuel lines, new fuel selector new plugs, carbs rebuilt.
I had the adjustments on the RAVEs wound all the way down, as I had read that is where they should be. Tried backing them out about three "clicks" but still doesn't seem to make much difference. Where should the RAVE adjustment be set at? Is there a real noticeable difference when they open.
It has RD flame arrestors on it. They were on it when I bought it so I don't have the stock air box. I've also read that it is difficult to tune these things with those on there. It does not seem to be running lean. I did a plug chop a while back and they looked good. Could it be that the main adjustments need to be opened up just a tad to compensate for those RDs
It does not seem to pick up any more speed between 3/4 and full throttle. Makes a little more noise but does not seem to go any faster.
Other than this it seems to run fine. No bogs or hesitation or surging. It does seem to have some pump cavitation on take off, but if the pump-wear ring clearance was off, wouldn't it tend to want to turn at a higher RPM than 6600?
Any suggestions appreciated
