1st off thanks for all the great help that I've gotten with this issue!
Ok, I've replaced the grey fuel lines:hurray:, cleaned out the selector valve, and cleaned out the water separator and carb fuel filter. After going for a lake test this afternoon the ski is still bogging down and shutting off when you go WOT, once you finally get to WOT if you pull the choke out it will cause the ski to bog down which I think means I'm not having a "Going to Lean Issue Correct." Also once you come down out of WOT you can take back off again with out bogging but if it sits and idles and then you go WOT it will bog out and die. So my next step, I think, is going to re-build the carb, is there something else that I should try first or something that I'm over looking? Also where is the best place to order a carb kit from? No one locally seams to have one.
Again thanks for all the great help!
Kelly
Kelly
