Hvymtlc5
2002 GTX. The steering cable locking nut failed (broke). I'm an older guy working off a lift at lake ozark (no trailer or place to take out)...plus it won't steer worth a darn.
Can I take the turn buckle off, pull the cable out from the inside, partially screw in the new locking nut with oring and half rings and slide the cable back through to the drive side and then tighten the nut. Or do I have to have the tool and put everying on the cable first from the outside and then tighten? Thanks guys
