Frozen cable?
Read the Manual on the R&R. At rear jetpump diconnect from the nozzel, inside compartment by that, loosen the nut at the thru hull, go back to rear and pull back the collar where it goes tru the hull and then the inside nut is a two piece wrap that
splits away, then remove the cables end so the cable can be pulled thru from inside. Take the front basket out to find the steering disconnect and note the adjustment, then remove cable. If your cable is frozen it can be freed up by twisting, then grease it after liberal movement. Bills86e
