Brprxt215
So I’ve had a starting issue all season with this. I have finally replaced almost everything in the ignition system(agm battery,solenoid,rectifier, oem starter) I am still having trouble starting it after it sits overnight. It’s almost like the fuel is leaving the fuel lines( all brand new) and draining back into the tank? There is no fuel in the bottom of hull but does have a mild gas fine smell all the time. Is there check valves somewhere that could be sticking? Someone mentioned to me to check the tank vent lines. What exactly would I need to check and do to fix it? Thanks in advance for the help!
