Hello to all! I am having trouble with intermittent 12 V power loss on my 1997 GTX. It will fire up perfectly fine one day and then the next day, after simply just sitting overnight, it will be completely dead with no gages with DESS key nor with double clicking the start stop switch w/o DESS key. Then a day later it will revert back to normal starts. On the water I’ve had it run perfectly and then found it dead again after sitting beached for a period of time. And then an hour later it will start normally. I’ve been trying to troubleshoot this on and off for about two weeks now which is made more complicated when the power mysteriously returns! Two different batteries known to be good have been tried. Starting system connections and grounds have been checked and are good as are all fuses. I’ve had the ski since new and maintained it well and all connections are clean and sound as far as I can see. There is not a trace of moisture or dirt inside the front and rear boxes.
Currently the ski appears to be “dead” but I have 12V on the yellow/red wire at the start/stop button, which I’ve verified as having continuity when pressed. The purple/red wire from rear electrical box has 12V coming into MPEM and leaving MPEM to info center. Yellow/red wire leaving MPEM and running back to solenoid does not have power. Seems like an MPEM issue to me but could I be missing something? Can the MPEM fail intermittently like this?
And as an aside, it seems there is an error in my wiring diagram in that the yellow/red running between start switch and MPEM is identified as yellow/black at the MPEM end. I’m no electrical whiz (mechanical engineer by day) but I can read. Anyone else see this in their wiring diagram or have my eyes gone buggy from studying the electrical “spaghetti” too long?!?!
Any suggestions are appreciated! - Mike
