cnpalmer
...just so I'm not going insane and the dealership/repair shop is telling me the right stuff!
I have a 2003 Sportster LE, 947 Rotax. When I bought the boat (used), it had no problem firing up 3 or 4 times. I had it trailered to my house and I did a ton of clean-up work on it, nothing in the engine though.
I recently brought the boat in to be serviced, compression test, plugs, oil etc. etc. I figured the $145 service was pretty reasonable seeing as I'm not familair with this type of engine and not sure of everything to check myself yet and I wasn't sure of the previous owner's maint. records as well.
Well, once it was there the engine wouldn't turn over. The DESS was attached, got the 2 beeps and then just a click in the starter relay. I went there myself to see what the tech was doing to troubleshoot... here's the details...
So given that series of steps, they're thinking it is the starter and needs replacing. How well does that jive with the troubleshooting they/I did and does that seem reasonable?
Also, are these starters just known "to go" like that? Any ideas what could cause it to fail? I've olny had it trailered to my house and then to the service shop.
Also, on this make/model they said the engine needs to be lifted to get at the starter, is that true to replace it?
They did check a ton of other things for me and the good news is my wear ring is in real good shape, of everything I thought that would be what needs to be replaced! :hurray:
I guess after all is said and done, for what I'm putting into the boat for repairs it'll be worth it since I only spent $3 large on it with the trailer.
- Checked battery charge level which was ok
- Checked other electrical functions, blower, lights, bilge all ok and no drain on the battery
- Jumped the solenoid on the starter relay, starter still didn't turn over.
- Hooked a hard switch up form the battery, grounded and then the hot to the starter and it still didn't turn over.
- Also attached a battery booster pack to the battery and did the same thing, still no turns.
- Also pulled the plugs and was able to push on each cylinder and the engine turns over so its no seized at all either.
