Do you mean don't over tighten screw?Be very careful with the bleed screw as they are easily stripped.
Would I need to check the gasket condition or just tighten bleed screw? Should I just loosen the inlet hose and cut a bit off and then re-tighten back on or replace with a new line? What hose would you use? Fuel line?That o-ring isn't going to cause an oil leak it just seals the case. Check to make sure your bleed screw is tight. Might be leaking there. Most likely your hose connection is leaking on the oil pump connection. This isn't your pump but the screw inside the red circle is the bleed screw. It has a gasket on it. You might want to clean the area to determine what is leaking before you do anything. I'll see if I can find the exact pump for you. This is not a 787 Engine pump in the picture.
I would verify the leak. As Miki said.... don't just tighten the bleed it might not and probably is not leaking. It is just something to check. Clean the area with some brake-kleen or something to get rid of the oil. and place a white napkin in there. For me the likely leak would be the hose connection and I would use the same hose just snip a little off the end, the length of the fitting perhaps. I substituted this hose once and had lots of trouble sealing it because they hose I bought was too rigid/hard.
To reiterate what Miki said... be very very careful snugging that bleed screw IF you touch it at all.
I'd love to know where to buy the proper line in bulk for the oil feed lines. You can purchase it from Seadoo but I want more than 3 feet for that price. LOL Good Luck.
I will get some paper towel today and put it underneath to see where its dripping. I thought I had some lying around but didn't. I did wipe the area clean two days ago so I could sort of see where the oil was coming from, I checked this morning and it actually feels dry underneath by the oil pump and inlet nipple but there was still a little stream of oil at the bottom of the hull so not sure if its coming from under the engine somewhere. Its a funny leak though because I first thought it was coming out the overflow of the oil tank so I stood the jet ski with the nose up and there was no leak or oil but when the jet ski is level or nose down there is oil at the bottom of the hull.
It also looks sort of like petrol and oil mixed that’s leaking. Black/purple oil with another clear fluid
The only hoses that get brittle and need to be replaced are the little 3/32” hoses from the oil pump to the intake manifold.
A bit off subject but it sounds like you may have the wrong oil in there based off the color.
What's the motor look like? Are you seeing seepage out of any of the seals?
Wish I had a picture of the vinyl hoses that came in my xp. All of them were stiff as a board and cracked in several places. This is perhaps because the ski had sat in someone's yard for 8 years with the wrong oil in them.
The stock 12mm & 8mm hose is polyurethane and will not get hard and crack. Vinyl hose is not what you want to use.A bit off subject but it sounds like you may have the wrong oil in there based off the color.
Interesting. Perhaps someone had previously swapped my hoses before I bought the ski.The stock 12mm & 8mm hose is polyurethane and will not get hard and crack. Vinyl hose is not what you want to use.
that should be fine as long as it's the api-tc low Ash. I just always think to double check when I see or hear about the blue colored oil.I’m using the quicksilver pwc 2 stroke oil. Where would I look to see if any seals are seeping?
