Hi guys
Got a little spx as a no runner. Built a motor for it and went through the thing.
It has a new carbon seal, Pump liner (wear ring) and a good stock prop. Clearances are fine. And i fitted a new foam seal.
But off the bottom it cavitates till its on the plane, Then its a bullet. At any time you can squeeze the throttle and it pulls hard.
It becoming anoying as i get slammed by waves as it wont pull up the face of them unless I carry a fair bit of speed.
Shouldn't these jump out of the water from a stand still?
Is there a problem with the pump shoe/ride plate sealing to the hull?
Any other ideas please?
