captain scale
I have a 97 GTX and when I got it the speedo was working at low speeds but erratic at high speeds. I figured it make have been due to engine noise or interferance. Now it doesn't register at all. All the connections appear to be fine. I get about 9v on the purple and yellow wire, about 5v on the middle wire and ground on the 3rd wire. The Lake Temp registers when the speed sensor is plugged in and does not register if disconnected. So it seems as if the wiring is fine. Is it possible that it just fails to send a signal for speed at this point? Everything else on my ski seems to work except the compass seems backwards!
