C CDA Spark New Member May 23, 2015 #1 How can you tell if the Spark has the HO engine? The 2 models appear identical on the outside, is there a way to tell from the VIN? Thanks.
RBB New Member May 26, 2015 #2 CDA Spark said: How can you tell if the Spark has the HO engine? The 2 models appear identical on the outside, is there a way to tell from the VIN? Thanks. Click to expand... assume dealer can look up serial number and tell but if it is a 3 up then its a 90, if it has ibr its a 90
hfgreg Administrator Staff member ADMINISTRATOR Moderator May 26, 2015 #3 CDA Spark said: How can you tell if the Spark has the HO engine? The 2 models appear identical on the outside, is there a way to tell from the VIN? Thanks. Click to expand... The 60hp will stay in touring mode. The 90 allows sport mode.
